Micro Magic в России • Просмотр темы - MMOexp COD BO7 and improved through deliberate practice
Сообщение JeansKeyzhu » 15 апр 2026, 09:36
In fast-paced shooters like Call of Duty: Black Ops 7, having perfect aim can be the difference between dominating the lobby and constantly losing gunfights. While good positioning, map awareness, and movement all matter, aim remains one of the most critical skills in the game. The good news is BO7 Bot Lobby for sale that aiming is a skill that can be trained and improved through deliberate practice. By using specific drills regularly, players can build muscle memory, improve reaction time, and become far more consistent in gunfights.
Here are seven powerful drills that can help you develop near-perfect aim in Black Ops 7.
Centering Practice Drill
Centering is one of the most important fundamentals of aiming. It means keeping your crosshair positioned exactly where enemies are likely to appear before you even see them. The better your centering, the less adjustment you need to make when a gunfight begins.
To practice this drill, load into a private match with bots turned off and simply run around the map. As you move through doors, hallways, and corners, keep your crosshair positioned at head level where enemies would likely be standing. Do not let your crosshair drift toward the floor or sky.
Focus on smooth movement while maintaining perfect crosshair placement. After about ten minutes of this practice, you will start to BO7 Bot Lobby service notice that your crosshair naturally stays at the correct height. This makes gunfights dramatically easier because your first bullet is already close to the target.
JeansKeyzhu
JeansKeyzhu JeansKeyzhu
